Frequency splitter(crossover?)
Shintylla
Unread post by Shintylla » 02 Jan 2016, 11:55
I'm trying to build a multiple frequency splitter so I can achieve multiple out from one input with different frequency, sort of blue cat audio plugin..
I'm not getting good result working with parametric EQ. I don't know if graphically it is accurate but to get the 0dB(graphically by the Qq's grid) in the 2nd frequency channel I have to rise it to +14dB and I'm not sure about the sonic result. I'll upload the patch so somebody might help me out.
thanks
Shintylla
Unread post by Shintylla » 06 Jan 2016, 12:35
Not an answer..
maybe a too simple question.
sephult
Unread post by sephult » 06 Jan 2016, 13:11
So your concern is about the accuracy of the Factory library EQ?
You could use Blue Cat Freq Analyst to monitor the output to see more clearly the accuracy?
-s
Shintylla
Unread post by Shintylla » 06 Jan 2016, 13:13
if you'd take a look onto the patch u would see what I'm talkin'bout.
frequency represented graphically are not the same.But mainly I'm needing some help in building a crossover with must outputs.
thx
gurulogic
Unread post by gurulogic » 06 Jan 2016, 21:54
I didn't look at your patch but maybe this can help? It is a 3 way crossover based on the Linkwitz Riley modules that I have used live on my 20kW sound system for shows and it sounds good to me.
http://www.sensomusic.com/forums/upload ... ssover.pat
btw, in the future you might have better luck with this sort of question in the patching questions section :)
sephult
Unread post by sephult » 06 Jan 2016, 22:03
20kW system guru, sounds badass ;)
Shintylla
Unread post by Shintylla » 06 Jan 2016, 23:15
Thanks guru,
patching section
Users browsing this forum: Google [Bot] and 406 guests
