Have you experimented detection troubles with behringer BCF or BCR ?
I have both units, and sometimes MIDI doesn't work properly. Generally just one unit, and just one way (MIDI in or out).
I have to close Usine, switch off and on the unit... sometimes it's not enough.
Once the dection is right everything runs fine.
I'd really like to find a way to avoid this.
Sometimes my behringer BCF/BCR are not detected correctly
I sometimes get issues with like my Akai APC20 which is USB. I will have to rescan and reset, sometimes disabling/enabling and it will recognize again.
Subsequent sessions will be fine, but will happen every once and awhile. I assume it's a USB ID thing.
-s
-s
La Tenaille
Hello Sephult.
I thought about cleaning my windows USB history.
I'll give it a try.
I'll give it a try.
Another thing I think to try to prevent from moving around and going to sleep is under Power Options -> Advanced. I know there is an option to suspend USB I always try to make sure this is set to off. This hasnt fixed my APC, but in the past has helped with some USB devices that just didnt act right after awhile.
Users browsing this forum: No registered users and 849 guests
