XY module to reverb parameters-TouchOSC XY problem
Shintylla
Unread post by Shintylla » 04 Nov 2015, 20:16
I have a problem:
i linked my xy module setting faders from -80 to +12 (as dry/wet knobs in reverb module); however from xy mod outputs come only 0 to 1. How can I change that without making some tricks with other data modules?
TouchOSC:
why from the app in the xy interface comes out only 1 value(x or y) and not both coordinates? Has anyone experienced this problem?
Thx
drakh
Unread post by drakh » 06 Nov 2015, 09:37
regarding the outputs from xy module,
1. you can use bindings - attach to the output send to data bus, and then bind it to the faders, usine will automatically map that 0-1 range to -80-12 range.
2. attach mapper curve module to the output and correctly set "min in/max in" and "min out/max out".
Option 2 is in my opininon better as with option 2 you have to as well somehow build unique name for the data bus.
Shintylla
Unread post by Shintylla » 08 Nov 2015, 15:23
Thanks drakh. I'll try that solution. Any suggestion with TouchOSC? I really can't find how to make 2 axis working fine. Usine in the trace panel reads the same input from both axis movements..Also from the forum on hextler.com seems really that nobody's taking care of the community and of the product..
Unread post by nay-seven » 08 Nov 2015, 17:20
about Touch OSC, have you read the user's manual ?
try the chapter named "OSC Control: Assigning OSC to a 2-Dimensional Object (XY)
Shintylla
Unread post by Shintylla » 09 Nov 2015, 13:13
Hi Nay,
i can't find online the manual with that chapter..
Unread post by nay-seven » 09 Nov 2015, 13:22
on the download page you 'll find the user's manuals
for example the Usine Hollyhock II user's manual (en) v2.0b.pdf
Shintylla
Unread post by Shintylla » 09 Nov 2015, 20:02
Nay, I was looking on the TouchOSC site. I misunderstood.
Thank you for your support.
Users browsing this forum: Bing [Bot] and 28 guests
