I'm working on a little workspace for an Octophonie Live performance.
All the workspace is ok but I've got a problem for my master track...
I've got some racks who are feed to an AuxFx rack.
My MixST rack and my AuxFx rack are routed to a master track.
My probleme is that I've got 8 input working on my AuxFx rack and I don't succes to have 8 output on this rack...
I put inside the rack an 8chanel Limiter.
Look at my screenshot to understand better.
Any Idea?
Thanks a lot.
Jules.
Routing Octophonie
no, we can't without asking access
check this tips to know how to add your picture directly on the forum
http://www.sensomusic.org/wiki3/doku.php?id=hollyhock:tips:how_to_add_screenshot_on_the_forum
2 things :
you need to put this octo limiter in the master rack, here seems to be in the AUFX rack ?
and i suggest you to create a real polyphonic limiter (open a stereo limiter patch, set all control to once in poly, then add a 4 polyphony to this sub patch)
Thanks Nay,
I think I need to limit at those two steps: Aux Fx and master.
But I had the problem for the first step, so I don't configure the master rack yet.
Thanks for the tips, I will do a polyphonic limiter next time.
I didn't know this patching technics, thanks for the advice.
And finally I've found the solution.
I had a looper which was hided in the Interface Builder...
It's difficult for me to memorize what is in the IB when it disapear in the workspace...
Any possibilities to keep the patch in the workspace when I decide to put it on the IB?
Anyway ---> Problem Solved
Thanks a lot!
J.
Thanks a lot!
J.
