Load samples by selecting folder
sephult
Unread post by sephult » 12 Sep 2015, 16:53
I would like to see the loading of samples by selecting the folder.
I have bundled kits, and libraries that would benefit from this. At the moment I have to enter each folder and select the contents,making it difficult to load several soundbanks at once in a sampler.
r.erorr
Unread post by r.erorr » 14 Sep 2015, 20:04
What do you mean by "loading of samples by selecting the folder"?
I'm looking for good sample manager soft, but unfortunately theris none satisfactory. It woud be nice if we coud transform usine like that.
sephult
Unread post by sephult » 14 Sep 2015, 20:33
So if I am using the list manager, I would like to just click and open the folder with all of it's contents populating the list manager.
As of now, you have to enter the folder and select all, then add to put in the manager.
-s
Unread post by senso » 10 Oct 2015, 11:03
almost implemented yet : the multi select is allowed in the openfile dialog window.
click "add files", select your folder and presss ctrl+A to select all files.
it does the trick?
Users browsing this forum: No registered users and 107 guests
