Usine Hollyhock II 2.0.081 update
Announcements
Unread post by senso » 31 Aug 2015, 18:17
[large]2.0.081[/large]
Many improvements and bugs solved.
Upgrade recommended.
improvements
- sysEx learn on all controls
- new quick link buses concept, see:
http://www.sensomusic.org/wiki3/doku.ph ... _quicklink
- new Chorus module
- new BrickWall Limiter module
- in the Midi sampler module, new comma text inlet to fill the sampler automatically
- new Templates
- new Filter response curve design
- new DLY Multi Bands x3 patch in the library
- Artnet/DMX, up to 4 plots panels.
- Pianoroll module: can now record midi channels informations
bugs
- GUI details in the GRAIN Cloud FX patch
- Midi Sampler MACOSX: load bank can crashes the application
- dB to Coeff Module doesn't work properly for arrays on MACOSX
- VSTTimeinfo SamplePos is not accurate
Unread post by oli_lab » 31 Aug 2015, 18:50
That's awsome !
sephult
Unread post by sephult » 31 Aug 2015, 19:30
Super Update!
-s
Unread post by cmodica » 31 Aug 2015, 20:20
YES ! GREAT.
Thank you very much
multiphone
Unread post by multiphone » 31 Aug 2015, 22:32
Thanks Senso !
This quick link buses idea is very smart
HB
Lines / Points / Squares
http://www.hervebirolini.com/
sephult
Unread post by sephult » 01 Sep 2015, 00:59
And you forgot to mention the FDN and Convolution ;)
...and that the new chorus sounds amazing on that Jazz bass.
-s
Unread post by senso » 01 Sep 2015, 08:48
sephult wrote:And you forgot to mention the FDN and Convolution ;)
they are only prototypes not officially supported.
CleverConQueso
Unread post by CleverConQueso » 09 Sep 2015, 20:46
Thank you very much for expanding the DMX/ArtNet support. This was very useful for our installation at Burning Man. I will post video as soon as it comes back.
shawnb
Unread post by shawnb » 12 Oct 2015, 21:16
QuickLinks are awesome!
Users browsing this forum: No registered users and 149 guests
