use an ipad as a touch screen in Usine
hi to the community.
I've just installed Duet Display app http://www.duetdisplay.com/ and I must admit that it WORKS ! (PC and MAC, tested on MAC)
Now:
- put patches in the toolbar,
- adapt zooms,
- disable 'auto reorganize' option of the toolbar
- put the toolbar on the ipad (viewed as a display monitor)
You can use touch controls on the ipad, unfortunately it's only mono-touch (because the touch events are transformed into mouse events). But not so bad.
It cost 15€
senso+++
Now:
- adapt zooms,
It cost 15€
senso+++
Personnaly i use idisplay for android and ios http://www.getidisplay.com/ it costs 3,99 euro and it works to
I wanted an USB connection. does idisplay works in USB or wifi? not clear on their site.
That's awesome, I've used VNC viewers before and actually was looking at this at one point.
Now what I want is iPad on the PC so I can use my iPad like a VST.
-s
-s
cool !
secretkillerofnames
Air Display 3 also works. It's best with the USB cord as Wi-Fi / Bluetooth is too laggy.
I think mono-touch is a bit limiting for serious use and there is still a bit of lag compared to mouse usage but it's pretty useful in my setup where i'm attempting to separate from the main computer + monitor when playing.
tested with a cheap android tablet and Mac 10.8.5
Idisplay don't work in usb here, works in wifi but not great , resolution issues and not handy
Air display 2 (3 works only for ipad) works fine (great with the Tool box) in wifi but a bit laggy, hope they'll update the 3 version for android
Users browsing this forum: No registered users and 491 guests
