Default colours...darker
osha
Unread post by osha » 28 Jul 2015, 12:16
When I go to Setup - Layout Style - Colour Style
I only get the one option, 'Default'. I thought there was a 'Darker' option?
Also...can I create my own default colour style (I am not a fan of purple!)?
nik_ost
Unread post by nik_ost » 30 Jul 2015, 00:23
As I understand you can modify colors by changing ResourcesColorsColorSet.ini file
It is quite time consumeng operation.... and you should bi familiar with understanding of hexadecimal color names.
But as a result you can change hateful purple to any colour you like...
Best,
Nik
Unread post by nay-seven » 30 Jul 2015, 08:16
And if you're on a Windows machine, you can use the add-on named HH Palette-manager to help you
osha
Unread post by osha » 30 Jul 2015, 10:59
Thanks.
The main thing I want to change is the purple waveform display in all the samplers. Which line do I need to change in the ini. file to do that?
Users browsing this forum: No registered users and 148 guests
