Drum trigging : sound according to velocity
La Tenaille
Unread post by La Tenaille » 04 Jun 2015, 21:28
I must say I'm completely noob about this, I've never used virtual instruments before :
I'd like to trig a hi-hat sample with a pad,, but of course if I use a single sample to play let's say semiquavers it sounds ugly, even with velocity and accents. I know sound banks have several sounds for the same instrument according to velocity, but I really don't know how to achieve this with Usine.
Can you help ?
Unread post by oli_lab » 04 Jun 2015, 23:53
you can use a good VST sampler as TX16
http://www.tx16wx.com/
Unread post by nay-seven » 05 Jun 2015, 08:05
Have you test the new Midi Sampler ?
http://www.sensomusic.org/wiki3/doku.ph ... di_sampler
note you can quickly open one by dragging a .bank file from the browser/sound/drums
La Tenaille
Unread post by La Tenaille » 05 Jun 2015, 09:09
The MIDI sampler looks great ! So for each midi note I can change sample and volume according to velocity.
Cool, thanks
Users browsing this forum: No registered users and 160 guests
