is there a way to easilly do math directly on 2D vectors ?
for exemple multiply a vector by a scalar, add two vectors, normalize a vector ?
or should I do my own fonctions ?
thanx
2D vector Math
Sounds like you want Eigen - http://eigen.tuxfamily.org/index.php?title=Main_Page
thanx !
Now I need more sleepless nights.
I have doubts : should I use float or long ?
martignasse
try with float before all,
but it really depends of the purpose,
until your computation need long because of intermediate approximation and precision limit of the float format. but you'll know that only by trying with float before
if it's 'only' to visually rotate a bunch of vectors, i don't see the need and extra memory of long.
DSP computation is another story and can benefit of long for intermediate result, even if the final number will be a float (as usine TPrecision is a float for now).
