I wish I could track these OSX lockups
secretkillerofnames
Unread post by secretkillerofnames » 04 May 2015, 08:32
I've been working on a setup for a performance tomorrow.
So far it seems Usine HH2 is stable once all the racks are in place - however I keep getting a frustrating lockup. I've not been able to track any particular thing causing it except it happens randomly when I add or delete a rack.
I get the spinning beachball of doom and have to "force quit".
It has happened 3 times in the last hour - just close enough together for me not to have saved my work properly.
If I had more clues I would put in a ticket but not sure there would be any use given the sporadic nature of the error.
Unread post by nay-seven » 04 May 2015, 08:53
if it's happen again,, try to save the logUsine.log file in another place before restarting Usine
you can open it with a text editor to see if you have error at the end, or send us this file to analyze
secretkillerofnames
Unread post by secretkillerofnames » 04 May 2015, 09:19
I do think one of the main problems is in relation to deleting a rack.
I've consistently had "Error: E032 in call Callback procedure" before closing / having to force-quit.
EDIT:I'll try and find this file.
Unread post by 23fx23 » 04 May 2015, 11:35
i looks like a script or user module error , maybe try to temporary delete if got some to spot the one causing this
Unread post by oli_lab » 04 May 2015, 18:48
I have this error sometime, I'll try to sahe the log next time as well.
I use user module and script ARGH !
Users browsing this forum: No registered users and 507 guests
