Precision about DMX control via Enttecc Open DMX USB
julien_
Unread post by julien_ » 21 Apr 2015, 13:23
hi,
i'd like to control my dimmer ( a starway tutelo ) with usine
I ve followed the step by step tutorial from the DMX manual but it doens't work.
i am a dmx newbie so maybe i am missing something.
But it seems simple :
Just Assign a DMX channel to the par created in the light universe in Usine, and program the physical dimmer with this same channel, that's it ?
julien_
Unread post by julien_ » 23 Apr 2015, 15:35
still the problem to use it but furthermore no more recognize by usine
yesterday my enttec open usb dmx was recognized by usine and today no more...
it that a action to do to reset the dmx parameters ?
martignasse
Unread post by martignasse » 23 Apr 2015, 18:08
Hi julien_
rescan device button should make it appear, is the enttec device plugged in the same usb port than yesterday ?
make sure the plot panel setting is on universe 0 and point to the good device number
julien_
Unread post by julien_ » 24 Apr 2015, 11:11
Non, toujours rien j'ai ressayé plusieurs fois, sur les deux ports usb, en redemarrant.
rien n'y fait, elle n'est plus reconnu.
Y a t il une manip pour réinitialiser usine à ces "réglages d'usine" :P
Unread post by nay-seven » 24 Apr 2015, 11:56
Usine est une application portable, donc il est possible de dezipper le fichier d'origine dans un autre emplacement pour tester une version vierge
julien_
Unread post by julien_ » 24 Apr 2015, 14:21
et bien non, ça fonctionne toujours pas...
Unread post by senso » 05 May 2015, 12:21
hello,
there is bug on the 068
you have to activate both options in the setup:
- DMX active
- Artnet active
in order to make dmx work properly in USB
will be corrected in the 069
senso+++
BatKam
Unread post by BatKam » 12 Jan 2017, 15:41
hello,
is the open DMX USB from Enttec is compatible on OSX and does it works on OSX with Usine ?
Thanks in advance,
Batkam
Users browsing this forum: No registered users and 78 guests
