Precision about DMX control via Enttecc Open DMX USB
hi,
i'd like to control my dimmer ( a starway tutelo ) with usine
I ve followed the step by step tutorial from the DMX manual but it doens't work.
i am a dmx newbie so maybe i am missing something.
But it seems simple :
Just Assign a DMX channel to the par created in the light universe in Usine, and program the physical dimmer with this same channel, that's it ?
still the problem to use it but furthermore no more recognize by usine
yesterday my enttec open usb dmx was recognized by usine and today no more...
it that a action to do to reset the dmx parameters ?
martignasse
Hi julien_
rescan device button should make it appear, is the enttec device plugged in the same usb port than yesterday ?yesterday my enttec open usb dmx was recognized by usine and today no more...
make sure the plot panel setting is on universe 0 and point to the good device numberJust Assign a DMX channel to the par created in the light universe in Usine, and program the physical dimmer with this same channel, that's it ?
Non, toujours rien j'ai ressayé plusieurs fois, sur les deux ports usb, en redemarrant.
rien n'y fait, elle n'est plus reconnu.
Y a t il une manip pour réinitialiser usine à ces "réglages d'usine"
Usine est une application portable, donc il est possible de dezipper le fichier d'origine dans un autre emplacement pour tester une version vierge
et bien non, ça fonctionne toujours pas...
hello,
there is bug on the 068
you have to activate both options in the setup:
- DMX active
- Artnet active
in order to make dmx work properly in USB
will be corrected in the 069
senso+++
- DMX active
- Artnet active
senso+++
ok thanks i will test that
hello,
is the open DMX USB from Enttec is compatible on OSX and does it works on OSX with Usine ?
Thanks in advance,
Batkam
Thanks in advance,
Batkam
Users browsing this forum: No registered users and 140 guests
