MIDI spread
secretkillerofnames
This seems like something someone would have thought of before. I've looked and not found it so apologies if I missed something obvious.
I'm using Numerology in Rack one currently sending MIDI to MIDI Bus1.
I want to create multiple racks with synth plugins and set a probability that the MIDI will pass through BUS1 to each synth.
It could be a percentage probability where 100% is all pass and 0 % is never pass.
It could also just be a RNG tested thing.
I thought MIDI Filter might do this but it seems I need something like a switch.
Any suggestions?
Any suggestions?
in the data/random generator , there's a random trigger with a density parameter
you can use it to trigger a pass flow module for your midi flow..?
secretkillerofnames
Thanks Nay-Seven.nay-seven wrote:in the data/random generator , there's a random trigger with a density parameter
When I set it up as a device sending the original MIDI through a data bus it seems to work pretty well.
But the Random Trigger controls can't be contained in the device area so I tried setting it up like this:
But obviously that isn't working because the output is a float not a MIDI value.
Tried sticking Quantize MIDI between Pass Flow and the plugin and still no luck.
chrs
Lloyd
you see floating data but Usine recognize Midi, the problem is more on the speed
here a better system:
Download
Download
secretkillerofnames
Great! That's definately something I can work with. I've recorded one test where it created a lot of hanging notes - i've yet to determine whether this is a plug-in or patch-related outcome - so will try a few more.
Thanks again.
Thanks again.
Hi secretkillerofnames,
I have a patch I am in the process of cleaning up and updating some things on that
performs a probability based in step with the Synchro.
This is just a beta and I figured it could give you some ideas in yours as well.
The bottom range fader shows the random triggering and the window of where it is possibly to trigger depending on the step.
I put in upload for you, and will probably release an add-on soon.
(Also built-in to my Advanced MIDI Sequencer that should be following)
You have me looking back now on how I made it too
Midi Probability
Midi Probability
secretkillerofnames
Thanks Sephult. I'll give it a try soon - work has been taking too much time.
Users browsing this forum: No registered users and 170 guests
