HSL Color Selector (user module) graphic version
Unread post by 23fx23 » 17 Apr 2015, 05:15
As a training for sdk, Ive build a custom graphical HSL color selector ( and also cause im missing it :p)
it allows to selec a color in 2 clics.
1) pick Hue in the 360 hue wheel
2) pick XY sat and lum in center square.
Outputs usine color and text HexValue. if wanna apply in usine color selector.
Nb: couldn't figure how to force initial size of module, so for best results size should be set to 400 to 400.
maybe drop in a contener and save as patch if find interesting to use.
ill try to improve..
ie the hue wheel doesn't really need to be computated and could be replaced by a still jpg in next version.
win32 win64 (couldnt compile mac :/
HSL color selector graphic version
hope some may enjoy. cheerz
martignasse
Unread post by martignasse » 17 Apr 2015, 09:32
cool :)
i have to test it
23fx23 wrote:Nb: couldn't figure how to force initial size of module, so for best results size should be set to 400 to 400.
in onGetModuleInfo you can set pModuleInfo->DefaultWidth and pModuleInfo->DefaultHeight, is that what you are looking for ?
(i saw that they don't appear in the API docs, i'll make correction today)
Unread post by nay-seven » 17 Apr 2015, 09:51
Great one 23fx,the preview zone is maybe small, of course it's easy to connect an object to have a better preview
hope someone can compile it for Mac , martignasse ?
Unread post by 23fx23 » 17 Apr 2015, 11:20
of Martin cool, i missed that indeed i had seen in one exemple cool :)
you 're right nay should make a better preview, will think about it.
don't know if i broke someting or if normal (im on windows) but only had win32 and x64 as compile option in Ms visualstudio (demo, i only have 20days left to make plenty of modules ^^)
i can give the code of course, so martin can see all my beginner mistakes & teach me master tips haha
ceasless
Unread post by ceasless » 17 Apr 2015, 17:39
If you share the code I will also try to compile :)
Unread post by 23fx23 » 17 Apr 2015, 18:01
yup here is a link to latest version src code, in case some manage to compile for mac:
https://drive.google.com/file/d/0B0VUyz ... sp=sharing
ceasless
Unread post by ceasless » 19 Apr 2015, 21:25
I haven't had a chance to try compiling it yet, but this is now in the Grove as both source and Windows binary :)
Users browsing this forum: No registered users and 125 guests
