FLAC support
Thomas Helzle
Unread post by Thomas Helzle » 27 Mar 2015, 00:05
Hey,
I just stumbled over the fact that FLAC isn't supported in the Usine samplers.
I seem to get more and more samples in this format - would it be possible to support it natively without converting or is that a bad idea for some reason?
Thanks!
Tom
sephult
Unread post by sephult » 27 Mar 2015, 00:41
Really, I very rarely see FLAC nor use it.
Mostly raw .wav, rex, and mp3.
.rex conversion to grain sampler would be really cool, except the fact that you need Recycle, or a license for export.
-S
Unread post by senso » 09 Apr 2015, 14:13
I'll see if it's possible to add a converter free to use in Usine.
Normally we have to pay royalties for that.
iococoi
Unread post by iococoi » 09 Apr 2015, 15:26
+1 for FLAC
and they seem to have a very open-minded license approach
..https://xiph.org/flac/license.html
ceasless
Unread post by ceasless » 09 Apr 2015, 15:32
Not just open minded, but fundamentally open. No patents, no royalties, no reason not to support :)
Thomas Helzle
Unread post by Thomas Helzle » 10 Apr 2015, 15:55
Thanks a lot Senso for looking into it.
Would that mean that you need to "hard-convert" the FLAC to wav/aif on disk or can you play back the file without conversion?
Because converting them to wav is what I want to avoid - I have tools that can do that already, but I would like to keep the footprint of those libraries on disk as small as possible.
I also started to use FLAC a lot for surround work, since it is one of the best delivery formats for it IMO.
With multichannel support, every bit- and sample rate under the sun and about half the size of uncompressed audio without losing quality it's really nice - and Audacity handles it very well.
So my Bandcamp projects use multichannel FLAC to deliver the 5.1 surround version (as "bonus item" since Bandcamp doesn't directly support surround yet):
http://excerpts-of-infinity.bandcamp.co ... at-i-on-ii
https://thomashelzle.bandcamp.com/album ... l-nature-2
There also is a brilliant player for such multichannel files (and all others as well): http://resonic.at/
So if it fit's into your concept for Usine, it could be a rather cool addition for in- and output.
Cheers,
Tom
Unread post by senso » 11 Apr 2015, 09:15
ceasless wrote:Not just open minded, but fundamentally open. No patents, no royalties, no reason not to support :)
maybe the time, a matter of priority?:)
ceasless
Unread post by ceasless » 11 Apr 2015, 11:46
Ah yes, well those are reasons not to support yet. :)
Jongleur
Unread post by Jongleur » 22 Apr 2015, 08:44
I unwanted files in the format flac 24bit, the use in plant Hollyhock would be appreciated:)
Jongleur
Unread post by Jongleur » 19 Aug 2015, 09:33
New on this subject. Thank You :)
Users browsing this forum: No registered users and 69 guests
