motorized upd on load and motorized with velocity
parityflux
Unread post by parityflux » 06 Apr 2015, 00:32
HH2
1) Is there a setting to send all motorized values out on workspace load (or workspace play)? For now I just use the "upd" button.
2) I have a patch button that I made "motorized". It works and sends out a MIDI note value when I click the button, and it ends up lighting up my controller. However it sends at a velocity of 127. Can I send a different velocity? I use a Livid controller and the color of the LED changes based on velocity.
The HH online manual refers to a Remote Panels wiki:
"Unfortunately, things can be more complex if you want to set special behavior to the control. You can access to the special features in two special windows. To know more about this section, have a look at the Remote Panels wiki page. "
But, I can't find it. It sounds really special ;)
Unread post by nay-seven » 06 Apr 2015, 14:33
1) try to add the mackie option to your motorized object
2) currently no, but exept if you have a lot of them, you can create it manually with a create midi module and a midi out on your rack?
3) The wiki page refer to =midi&s[]=learn]this page
parityflux
Unread post by parityflux » 09 Apr 2015, 07:41
1) the Mackie option does not seem to have any effect. For now "upd" works great. Request workspace option: "upd" on load.
2) I am now transforming the data on the way in (on the IN device). I'm satisfied with this approach at this time. [The controller manufacturer, Livid Instruments, does not currently supply a way to do this, so my only option is to do it one way or another in Usine]
3) I was looking at: =remote&s[]=panel]MIDI Learn & Key Learn ...next to the "important" symbol.
Unread post by nay-seven » 09 Apr 2015, 09:46
yes transforming data in the In device is a good idea
the page you refer is an archive of Usine hollyhock 1 wiki , and complex learn refer to key learn, no midi learn
Users browsing this forum: Bing [Bot] and 71 guests
