Current Patch Number
gurulogic
Unread post by gurulogic » 03 Apr 2015, 21:45
Now that HH2 has reintroduced the Load Patch module which is able to set rack number and patch number, is there any way to get the patch number? I don't see anything available via module but perhaps there is IML or script to access to this value?
sephult
Unread post by sephult » 03 Apr 2015, 22:14
You mean like which patch order from top to bottom in a rack, or like the actual ID of the patch?
-S
gurulogic
Unread post by gurulogic » 03 Apr 2015, 22:43
Patch order in rack.
sephult
Unread post by sephult » 05 Apr 2015, 09:11
Yeah I don't think there is anything implemented yet, you should put in a suggestion.
I was trying to look if you could extract from a rack file, or somehow through the IML....so far I have not found anything.
I will keep looking though...but would be a good suggestion to have natively within the Rack Settings....maybe how many patches in a rack, as well as patch settings including the order in the rack.
-S
ahonoe
Unread post by ahonoe » 08 Apr 2015, 23:43
Completely agree. Patch numbering info would be quite helpful.
Regards,
Scott
