WHERE WOULD i GO TO SOLVE THIS
joojoo1234
Unread post by joojoo1234 » 16 Nov 2007, 18:17
My 1010 saffire interface gives me static more and more as I work on the using project and I have to reset it to clear it. It is sitting on my computer - is this the problem as I have killed my background processes... anyone know a good site where these things are discussed. I am a wood and steel musician for the most part.
Golcondio
Unread post by Golcondio » 19 Nov 2007, 08:43
Well, if you think it's due to positioning, try moving it around the room!
First of all, is all of your gear connected to a grounded electricity grid?
Have you tried using a shielded socket?
What is your setup? What's connected (both in and out) to your interface?
Did you check the cables and the power cords?
Toshiba m40-281, Motu Ultralite, dbx166A compressor, Vassilevsky tap-guitar, M-Audio Oxygen8v2, Usine
joojoo1234
Unread post by joojoo1234 » 19 Nov 2007, 12:19
I have got 90% of it gone by loading basic services and lowering my graphics card acceleration and eliminating the firewall on my firewire which I did not know I had... I will look at the other 10%
joojoo1234
thanks for replying by the way.
Users browsing this forum: No registered users and 701 guests
