compatibility with Hollyhock II
Unread post by cmodica » 06 Mar 2015, 16:25
I need to begin to build a new workspace for a new project.
Did the Hollyhock I workspaces will be compatible with the new Hollyhock II ?
Unread post by nay-seven » 21 Mar 2015, 09:34
yes, no compatibility problems
Unread post by cmodica » 22 Mar 2015, 12:09
Great !!! Really wonderful because i am working on few projects with Hollyhock and it will be great to transfer them on Hollyhock II
pgusern
Unread post by pgusern » 25 Mar 2015, 16:50
hi,
Not so easy... I experiment two issues with hollyhock 1 workpaces.
1 with a patch using kontakt5 ; Kontakt seems to load normally, but the patch doesn't appear in the rack, (and sure is not playing).
2 with a patch using the filelister module: I get an error message "invalid path in the filelister module".
Concerning the first issue I tried to rescan plugins after importing my previous setup from HH1.
Precision I'm on a windows 8.1 system
Unread post by nay-seven » 25 Mar 2015, 17:31
Sorry to hear that,
Can you please take a little of your time to create 2 report tickets
Unread post by cmodica » 25 Mar 2015, 19:03
Old Kontakt patches works fine in OSX. Everythink seems to be ok.
Clearscreen
Unread post by Clearscreen » 26 Mar 2015, 01:39
I've had a patch with kontakt and a piano roll disappear in a rack - it's still there I think, I can hear it, but the patch doesn't appear anywhere in the interface... I'm gonna see if I can make it happen and nail it down as a bug...
Clearscreen
Unread post by Clearscreen » 26 Mar 2015, 02:37
Yep - it just did it again on a different workspace... Somethins going wrong with kontakt... I'll file a bug report.
sephult
Unread post by sephult » 26 Mar 2015, 06:19
Hi clearscreen,
I just wanted to ask...because I had a problem where I lost my interface and had "phantom" sound.
There is an alternate workspace button now in Hollyhock 2 in the top left.
I had found myself with some racks I must have got loaded in the alternate, and switched....well I was getting really confused until I realized it was playing from the alternate workspace.
Hearing sound and no patch...that just reminded me of the issue I ran into.
I am running Native Instruments stuff here too, if you would like another verification I can try out if you upload your patch.
-S
Users browsing this forum: No registered users and 403 guests
