From PointsCurve to MapperCurve
I would like to draw curve on PointsCurve module(because its easier and more smooth) and them apply it to MapperCurve. Unfortunately there are two array outputs(x,y) from PointsCurve module, but MapperCurve have just one array inlet. Is it possible somehow convert those two outputs to one array so I can use it fore MapperCurve?
You should be able to concatenate the array.
Just tested, Place an array concatenate between the XY of the points curve, do an array set size controlled by the Num of Steps, and take the output to the Mapper Curve in User Mode. If you Just concatenate the MapperCurve will double the Array Value, this is why you need to set the array size to the steps.
-S
-S
The mapper curve does not have an adjustable X, and seems to be only defined by the resolution of the array.
Just wiring the Y with an array set size will work as well because of this.
I think the mapper curve is actually a much smoother and easier to define, smooth curves.
In the opposite direction you can really see the difference.
-S
-S
Hmm . . . probably I think visually, but problem is somehow related that distance between points is not equal to steps of array. I made some screens:
I think I once made a script just for this - probably in v5. If so, I am opretty sure I uploaded it as an add-on. I'm at work now and don't have time to search around.
Yes, exactly Points Curve to Array
Thanx
Thanx
i can't get access to dowload /add on section and i would need back this scipt, any chance one of ya paste the code here on the forum ?
never mind, found it back via changing url
. working on a blurring/smoothing array script that goes well with this one, might interst ya r.rttor
will post a bit later..
Users browsing this forum: No registered users and 38 guests
