Extract file name / extract file ext
AndrewChi
Unread post by AndrewChi » 12 Feb 2015, 16:24
I need some help...
I am trying to save a random sample name and a text file with the same name.
This works, but I also need to extract the file name WITHOUT extension (.WAV and .TXT) later on to work with it in the patch.
the module 'extract file ext' extracts the extension,
but the module 'extract file name' gives you in fact the 'short filename' but it still has its extension.
Any ideas on how to really extract the file name, without its extension?
Any help appreciated, thanks!!!
Unread post by senso » 13 Feb 2015, 00:00
You can use this small script
Code: Select all
// sub File Ext
// parameters declaration
var input     : Tparameter;
var output    : Tparameter;
procedure init;
begin
 SetModuleColor($808080+302060);
 Input := CreateParam('full file name',ptTextField);
 SetIsOutPut(Input,false);
 output := CreateParam('out',ptTextField);
 SetIsInPut(Output,false);
end;
procedure Callback(n:integer);
begin
 SetStringValue(Output,copy(GetStringValue(Input),1,length(GetStringValue(Input))-4));
end;
Will be integrated in the next major release
AndrewChi
Unread post by AndrewChi » 13 Feb 2015, 03:23
Great! Thank you very much for your fast reply Senso. Works perfect!!
