.peak files everywhere?
Interesting question.
Could create an executed batch file to delete all the .peak files. I use simple batch files a lot of times to search for things to sort and delete.
Could also execute it from a patch.
-S
-S
Mmm that sounds like windows....I'm mac. I was hoping for a preference but I don't think there is one.
the .peak file is used to accelerate waveform drawing of audio files.
It's a very common behavior, like for example in reaper.
No way to disable the creation. If you delete them they are automatically recreated next time you load the file.
In the next version, this file will be optional, depending on the memory location (memory or file)
can try to sort by type maybe? thats what i do personnally
great that was my hope. Thankssenso wrote:In the next version, this file will be optional, depending on the memory location (memory or file)
I am also often annoyed by .peak files cluttering up audio folders. What would be helpful is an option to store them all in one out of the way location as is found in Reaper and indeed most DAW applications.
Users browsing this forum: Google [Bot] and 405 guests
