Patcher text on Mac
osha
Unread post by osha » 09 Jan 2015, 16:09
Hi
The text on the Patch window on the modules is really difficult to read. The black text is tiny and very grainy/broken up. Cannot zoom either on this window.
Tried different screens and its the same on my Macbook Pro 13", on a 15" Mac Perspex screen and a 21" BenQ.
any ideas?
sephult
Unread post by sephult » 09 Jan 2015, 17:55
In the settings there is a global zoom that you can use. Ive had to modify this a time or two for my tablet.
I generally do not find problems with reading this text, so maybe you modified this setting before and didn't realize?
-S
sephult
Unread post by sephult » 09 Jan 2015, 17:56
Its under the Touch Screen -> Global Zoom Scale and I believe the default is 1.00
osha
Unread post by osha » 09 Jan 2015, 19:47
Thanks ...but it's not that. I tried changing it and it makes little difference unfortunately.
Also if you are on a Mac have you noticed the mouse jumping when you click on a parameter...really strange , it jumps a good inch when I try to click on a horizontal parameter slider in Properties....
Unread post by senso » 09 Jan 2015, 20:31
welcome osha,
few info
I use myself a mac...
1)the mouse jumping let the cursor fits the position of the current fader designed like that, not a bug... you will appreciate it on stage to avoid big jumps
2) the next release will have a more contrasted design in the patching window
senso+++
sephult
Unread post by sephult » 10 Jan 2015, 00:22
I am the windows user :)
I agree, with the mouse jumping at first it takes some getting used to...but I have learned to love it.
I have a friend I work with who was not used it as well, for windows at-least I told him when he wants to change a parameter....do a triple click and he picked it right up.
-S
osha
Unread post by osha » 10 Jan 2015, 01:20
Ah wow OK I'll try getting in to that. Unusual.
Lovin Hollyhock btw. really very impressed. The user interface takes a little getting used to but wow there are many wonderful finds and such amazing potential here. Will be purchasing as soon as the tax man has his fill!
Users browsing this forum: No registered users and 148 guests
