Any usine with Quneo user?
Unread post by 23fx23 » 17 Dec 2014, 17:04
hi freaks,
im very interested in quneo controller as i seems it could handle various visual feedbacks and tactile stuff, plus osc so it might be very sexy with usine. wonder if any got it and could share experience/impressions?
Unread post by 23fx23 » 19 Dec 2014, 12:59
just bought it anyway^^ and first imresisons is it's quite an awesome device .build in modularity seems very deep, so i can't imagine how fat/far it can go with usine :V gonna try to make little tests vidz with usine and report a bit later..
sephult
Unread post by sephult » 19 Dec 2014, 20:59
hello fellow freak,
quneo? Sounds like a Spanish controller?
Actually never heard of it....ahh now I know what it is. Yes I have seen online before but really not much else.
Definitely interested on your thoughts with this? What kind of price did you get?
-S
Unread post by 23fx23 » 20 Dec 2014, 11:00
http://www.keithmcmillen.com/QuNeo/tour
got it for 195 euros here in france. will repport with later extensives tests but i really feel gonna like it ;) it's osc compatible
edit: it is globally multitouch, quite flat/handdy for travel, and each contol can send on/off, XY, and pressure! one is dual touch and two rings are already patched to be able to send distance/direction from center. very trippy ie to switch on an fx while also being able to tweak it, tho i haven't deeply tested yet precision accuracy . currently installing the osc bridge to ctl each lighting feedback separately^^ good night in perspective^^
shawnb
Unread post by shawnb » 20 Dec 2014, 17:26
Sounds like a good fit for HH!
(Though I thought quinoa was a cereal...)
iococoi
Unread post by iococoi » 21 Dec 2014, 14:08
keep us updated, won't you. i've got one lying around somewhere. one from the original kickstarter( with sleeve+tshirt).
23fx23 wrote:http://www.keithmcmillen.com/QuNeo/tour
Unread post by 23fx23 » 21 Dec 2014, 15:04
yup no pb. here is just a basic visual feedback test as teaser^^, but with live (oops^^) and a vst to output rms to cc. but will be much much better and modulable with usine. i can already imagine nice sequencers/mx ect... will report the ctrl stuff later when more deeply assigned/tested.
https://drive.google.com/file/d/0B0VUyz ... sp=sharing
(as exemple there are ovrloads as i got really small buffers settings, but with usine i will be able to filter the amount/rate of data to send)
Users browsing this forum: Google [Bot] and 614 guests
