multi format OSC
Unread post by oli_lab » 07 Nov 2014, 07:24
I can't find anything about OSC in the SDK
would it be possible to build a module that send multitag OSC message from the SDK ?
thanks
martignasse
Unread post by martignasse » 07 Nov 2014, 11:38
hey olivar,
the OSC system isn't exposed in the SDK at all
and i think it's not a good solution to try to go this way
if multitag is the "ultimate/last" functionality missing about OSC, a "feature request" is the way to go ?
martin
Unread post by oli_lab » 07 Nov 2014, 12:08
I spend last evening building a sub patch with arrays, strings and udp send and few other modules but not yet tested on my HW OSC server.
I'll post it asap
Unread post by oli_lab » 08 Nov 2014, 15:39
Users browsing this forum: No registered users and 5 guests
