I'm building an interactive patch were someone can choose from a soundbank, choose to fiddle with some parameters, and then listen to the result.
to do that, I have to attach some metadatas to each files, such as markers, the range of the pitch values, filter values that make the particular sound interesting...
I managed to do that with a array memorizer and a preset manager... but it is not as professionnal as it should be... and a pain to edit.
What I'd like to do is a spreadsheet (.CVS) that can be saved as a file and be externally edited from a text editor, the readback from Usine to load a file (from long file name), and taking into account the metadatas.
would anyone has an idea ?
thanx
save comma text to file, edit and read it !
I managed something, not a CVS but many text files...
used the "write text example" and made a "text file reader"
<code>
// write text File
// declaration
const filenameDefault = 'c:speak.txt';
var fname,input : Tparameter;
var st : TStringList;
// save
procedure SaveToTextFile;
begin
st.create;
st.add(GetStringValue(input));
st.SaveToFile(GetStringValue(fname));
st.free;
end;
// Callback
procedure callBack(n:integer);
begin
SaveToTextFile;
end;
procedure init;
var i : integer;
begin
Input := CreateParam('in',ptTextField);
SetIsOutPut(Input,false);
fname := CreateParam('file name',ptTextField);
SetStringValue(fname,filenameDefault);
SetIsOutPut(fname,false);
end;
</code>
<code>
// Read text File example
// declaration
var fname,textOut : Tparameter;
var data : array of single;
procedure init;
var i : integer;
begin
textOut := CreateParam('out',ptTextField);
SetIsInPut(textOut,false);
end;
// read
procedure ReadTextFile;
begin
//read the previously saved file
st.create;
st.clear;
st.loadfromFile(GetStringValue(fname));
SetStringValue(textOut,st.GetStrings(0));
st.free;
end;
// Callback
begin
ReadTextFile;
end;
</code>
<code>
// write text File
// declaration
// save
begin
st.create;
st.free;
end;
// Callback
begin
SaveToTextFile;
end;
procedure init;
var i : integer;
begin
end;
</code>
<code>
// declaration
procedure init;
var i : integer;
begin
end;
// read
begin
st.create;
st.clear;
st.free;
end;
// Callback
begin
ReadTextFile;
end;
</code>
well, I'm getting somewhere
tell me what you think !
http://www.sensomusic.com/forums/upload ... datas1.pat
