Cycle length max of 16
raintalk
Unread post by raintalk » 29 Oct 2007, 06:58
So I see the cycle length has a max of 16. I'm wondering why the hard limit? Some plugins can follow the bar # and so can only do 16 bars with Usine, before having to cycle back.
Unread post by senso » 29 Oct 2007, 14:26
I can Change it without any problem.
do you want 32, 64, unlimited?
The same for bar length
raintalk
Unread post by raintalk » 29 Oct 2007, 17:09
Wow - thanks
What I would ideally like is to be able to change them to anything up to unlimited.
Unlimited could just be a large limit, i.e. 32k if limited by the container that holds the value.
Of course as long as performance and behavior remained the same.
thanks,
Unread post by senso » 30 Oct 2007, 20:59
Now the cycle length value is unlimited if you use the editor (dbl click) or max 32 if you use the mouse.
The bar length max is now 32 beat / bar.
Next release.
Vincent
Unread post by Vincent » 30 Oct 2007, 22:26
senso wrote:The bar length max is now 32 beat / bar.
Hmmm, I think I shall have to go back to school... BTW have they be informed? We can now build only with prime bars. Great esoteric opportunities.
vincent michel
composer & novelist
Users browsing this forum: No registered users and 196 guests
