Hi, I have some problems with the current version that were not in the 3.0.
(short pauses every few seconds while playing 16 channels files).
Since I don't know if it is really due to this build or to anything else (but I have no problems in other softwares) I would like to try with the old one before saying that there is a problem... but I have no more the file...
Is there a deposit where finding old versions ?
Old versions download ?
jean-marc duchenne
if not and as senso is on tour , i have some old one if you want...
tell me and i put it on a share place or contact via mail if you always have mine...
I'm at home now.
Actually no way to get the 3.0 version directly.
We are working on a special area in the download page for an access to older versions, but not yet implemented. Soon I hope...
Same remark than nay-seven I can send you any version you want.
But normally there is no difference in the wave player engine in the v3.0 and the V3.30. I've just re-tested at home without problem.
Check your sound card latency?
Try to restart Usine to re-buffering files?
jean-marc duchenne
This buffering thing is really weird...
It takes nearly five minutes to load the project (12 multichannel files), and after there is always some playing problems with some files that make is totally unusable.
The short pauses happend both with the sample player (streaming from disk) or the sequencer.
Some files play well but there is always some that have this problem, not always the same files.
It happends also if there is with fewer files loaded.
I have tried all sort of latencies, no change.
I don't understand this buffering stage and why it take soooooooo long time. In Bidule or Audiomulch I can play the same files directly without any problem and without any load time.
What is it for ?
What is it for ?
I'll go deeper in my investigations and try to find a better buffering procedure.
It a priority.
It a priority.
Users browsing this forum: No registered users and 1735 guests
