Using Panel, Image, Picture
You could try doing this.
This way you have a list available to add your .jpg to and a dropdown menu to switch between them at will.
Thank you very much for repplying: I was trying to do do something like this. I forgot to say I'm using USINE STAGE 5.80 and in HOLLYHOCK some things has changed, many modules are different and some are new." List Manager" is not available, probably is a variation of old list box, "Panel,Image" is different now, "Combobox" it is also different
This is what I have so far and don´t have a clue how to make them work the way you suggested.
yes, you have to use the old method
create several panel image/edit layout and click on back bitmap to load your picture, set those panel image to invisible, then link this way with a selector
Users browsing this forum: No registered users and 138 guests
