Using Panel, Image, Picture
Ariajazz
Unread post by Ariajazz » 28 Sep 2014, 05:45
Just don't know how to use this feature. How do I indicate the path for the image file? Is it possible to set a list of files to choose from?. My intention is to open music sheets in jpg format.
Tackla
Unread post by Tackla » 28 Sep 2014, 10:10
You could try doing this.
This way you have a list available to add your .jpg to and a dropdown menu to switch between them at will.
Ariajazz
Unread post by Ariajazz » 28 Sep 2014, 16:47
Thank you very much for repplying: I was trying to do do something like this. I forgot to say I'm using USINE STAGE 5.80 and in HOLLYHOCK some things has changed, many modules are different and some are new." List Manager" is not available, probably is a variation of old list box, "Panel,Image" is different now, "Combobox" it is also different
This is what I have so far and don´t have a clue how to make them work the way you suggested.
Unread post by nay-seven » 28 Sep 2014, 18:16
yes, you have to use the old method
create several panel image/edit layout and click on back bitmap to load your picture, set those panel image to invisible, then link this way with a selector
Ariajazz
Unread post by Ariajazz » 28 Sep 2014, 18:36
Thanks a lot I will try it later on
