Using the sampler player play button in loop mode
noise2sine
Unread post by noise2sine » 16 Aug 2014, 23:55
My question concern the Sampler Player in Usine V5. Is it possible to have the same possibility as with the piano roll to set the loop mode and at the same time having the play button working ?I have 8 different piano roll, and all are in loop mode, and all have their play button assigned to the same keyboard letter.So it's easy to re synch all the piano rolls.It would be nice to do the same with the audio sampler player.Now if i'm setting the loop mode on the sampler the play button doesn't work, and if i set the the play button mode, the sample is played only once :) . Can i have the two option ?I mean a start from begining button and the loop mode ?
waolelaid
Unread post by waolelaid » 17 Aug 2014, 22:26
http://www.sensomusic.org/forums/upload ... 20need.pat
Hi noise2sine here is a patch that Nay gives me when i asked the same question
in fact in the combo box Button = 0
Loop = 1 etc .......
so you can test it there is no problem
hope it helps
best :)
Friedrich Nietzsche
noise2sine
Unread post by noise2sine » 26 Aug 2014, 12:51
Thanks for the patch :)
I found an another way to get the result expected : i have used an event module ( 1 to 0) connected to the start position of the sampler.It's working perfectly.
waolelaid
Unread post by waolelaid » 26 Aug 2014, 16:34
Hi you found another workaround but i don't know how you wire it ?
can you give a picture ? if you have time i'll learn another thing it's for me the only manner
to learn or understand some thing in usine
best :)
Friedrich Nietzsche
noise2sine
Unread post by noise2sine » 27 Aug 2014, 11:34
Inside the patch you will find two restart button because they are in relation with going up (key learn + ) and down ( key learn -) with the conductor.They have the same key learn.Everytime i'm going up or down with the conductor the restart button is pressed so even if the sampler is in loop mode it will start from the begining at every changes.
Hope it helps
http://www.sensomusic.com/forums/upload ... 20mode.pat
waolelaid
Unread post by waolelaid » 27 Aug 2014, 17:56
Hi noise2sine and thanx i'm sure it helps
i'll learn a new thing in usine and for me it's very important
wish you a good afternoon
Best :D
Friedrich Nietzsche
Users browsing this forum: Bing [Bot] and 111 guests
