Routing in HH
tanabarbier
Unread post by tanabarbier » 28 Jul 2014, 17:36
Hi everybody,
I can't get my head around the concept of routing in HH, I am trying to do the same things I could in Usine 5, like using a track as input of an other track, having a master track, etc, but I can't figure out how.
I looked in the HH manual and did not find anything about routing.
Could someone please help me by pointing the right direction?
Thanks in advance!
sephult
Unread post by sephult » 28 Jul 2014, 17:44
Hi tanabarbier!
So as far as routing...drag the source rack to the input of the rack you want to route to.
If you have two racks you want to send to a single rack to say compress the two signals drag both racks into the input of a third.
If you only want to hear the output of the Master rack you could just delete the stereo output of each of the first two racks.
I have made an audio distribution system based similar on this, i have some cleaning up to do so maybe Ill put in the add-ons, but basically it is just drag and drop rack into input....etc..
sephult
Unread post by sephult » 28 Jul 2014, 17:49
As a template you could say create a 16 Rack (track), delete all of the stereo outputs of each individual rack. Make a Master Output rack which contains the Stereo Output device. Minimize all of your outputs on each of the source racks. If you open the mixer then you can drag all of your 16 + 1 racks into the mixer container for a nice clean "Common" mixer setup like most people are used to with common DAW.
Users browsing this forum: No registered users and 350 guests
