master popup and/or container, sliding IB, resizable toolbox
La Tenaille
Unread post by La Tenaille » 04 Jul 2014, 09:35
I'd like to have a way to display different elements from different racks in a single window.
> The toolbox is not resizable and can't be unlocked.
> My IB is already used for live setup.
So what about master popup, container, or more pages for the IB ?
Unread post by senso » 20 Jul 2014, 09:56
There is a concept of "HEAP" which is a small ID displayed in stand alone window and does exactly what you describe.
Actually the HEAP is an hidden feature and I don't know if it will be available in the next major release.
La Tenaille
Unread post by La Tenaille » 11 Apr 2015, 11:52
So today, any way to have an other "master display" ? What about a secondary windowed IB ?
sephult
Unread post by sephult » 11 Apr 2015, 15:42
Hi la tenialle,
The only thing I could find as of today is doing how I was suggesting. Bussing to a master patch and using a pop-up in floating-window mode.
Then you can position objects in the pop-up and move to another display. This is the only other way I can see at the moment.
I too would love to see more global windows, would be cool to have like a Workspace Pop-up you could send things too, or several toolboxes which can be unlocked and resized.
-S
ahonoe
Unread post by ahonoe » 16 May 2015, 17:22
Along similar lines, would it be possible to add a "where" setting to VSTs. I'd love to combine VST UI panels with my hh controls.
Regards,
Scott
Unread post by senso » 15 Jun 2015, 18:07
ahonoe wrote:Along similar lines, would it be possible to add a "where" setting to VSTs. I'd love to combine VST UI panels with my hh controls.
unfortunately impossible in a cross platform application like usine...
Users browsing this forum: No registered users and 27 guests
