Display elements from different racks/patches in a single window
La Tenaille
Unread post by La Tenaille » 03 Jul 2014, 11:26
Is this possible ? I have 10 tracks with FX and would like to tune them all from the same place.
I've tried the toolbox but I can't organise it the way the IB does.
IB is not a solution as I don't want to display them on stage.
Using controllers sent to buses seems a disproportionate method.
gurulogic
Unread post by gurulogic » 03 Jul 2014, 18:41
I had no idea before looking at your problem that I could put interface items in the toolbox! Maybe this is your best choice? If you organize your controllers into sub patches with containers and put these containers in the toolbox? Or else maybe a one switch control to show/hide multiple sub containers in the ib?
La Tenaille
Unread post by La Tenaille » 03 Jul 2014, 21:40
The toolbox is nice, but it's a narrow strip that can't be resized in height.
Your idea of a kind of "multi container" layer in the IB, that can be hidden with the same shortcut is nice.
I thought the IB could be slided but this feature has disappeared.
Thanks for your tips ;-)
gurulogic
Unread post by gurulogic » 03 Jul 2014, 23:05
Another idea is put all your controls in each sub patch control panel, then put each sub patch in the toolbox. This way you can mininimize/maximize each set of controls as needed.
La Tenaille
Unread post by La Tenaille » 04 Jul 2014, 10:49
I've found a weird but working workaround for the toolbox.
I had that :
as you can see the toolbox is not large enough to display all the patches
so I've added a fake patch in the toolbox, with container and text element placed at the bottom of the conatiner and this is the result :
A pity the toolbox can't be organised the way the IB does but this works ;)
gurulogic
Unread post by gurulogic » 04 Jul 2014, 18:24
In my case, I have my devices in the toolbox, when I open the binds panel I get a similar result. Yes, it would be useful to be able to lock positions in the toolbox.
