Double click on module / settings panel
gurulogic
Unread post by gurulogic » 20 Jun 2014, 05:45
I think it would enhance the workflow if when a modules settings panel were pinned, double clicking a different module would switch the pinned panel to display the settings for the selected module, but still pinned. Also if opening the settings panel for a new module after closing it while pinned, the panel would open for the chosen panel and still pinned.
In my case, especially considering my small display, I find it confusing to have a varying sized settings panel open for each module I click so I would prefer to work with the panel always pinned but with the capability to quickly switch between settings views for different modules.
Hope this makes sense..
gurulogic
Unread post by gurulogic » 20 Jun 2014, 07:10
Also finding it a bit of an inconvenience having the settings panel pop up every time I open a sub patch.
gurulogic
Unread post by gurulogic » 20 Jun 2014, 20:27
Another time saver would be a shortcut to navigate back and forth between previously opened patch windows, similar to how it is done in an internet browser. Perhaps something like Shift + Arrow keys? (or even clickable <> at the top of the patch window?)
Unread post by woodslanding » 21 Jun 2014, 00:35
+1 for patch window history!!!!
Unread post by senso » 29 Jun 2014, 14:21
good suggestion.
- pined modules: normally it should be
- history: possible but how to find the right ergonomics for that? that's the question. the menu bar starts to be very populated...
ceasless
Unread post by ceasless » 29 Jun 2014, 14:31
Maybe some left/right buttons next to the patch name at the top of the patch window would work? History would be very cool indeed.
Unread post by woodslanding » 29 Jun 2014, 16:41
well #2 could be a command available only with a key-stroke if there's really no place to put it.
#1: I really dislike the settings panel changing size. If it goes to 3 columns I basically can't do anything. And many times when I double-click on an object, the first click changes the number of columns, and obscures the object so the second click doesn't work.
I will ask again for the option to have a scrollbar on the settings window instead. I don't see why it needs to behave differently than the browser window. Actually, it would be a MORE welcome feature on the browser window than the settings window. In the browser window, I could easily close a branch of the tree to get it back to one column!
So maybe another solution would be putting module settings into a tree-table format. Big change, tho, I guess ;)
cheers!
-e
Unread post by senso » 29 Jun 2014, 23:43
for info : pined modules and history will be implemented in the next major release
gurulogic
Unread post by gurulogic » 30 Jun 2014, 00:46
Great news! Thanks! And no setting panel popping up every time I click on a patch or sub patch? (floating windows mode). This has been driving me crazy! ;)
Users browsing this forum: No registered users and 54 guests
