Previous and Next buttons on VST window not working.
Blaakk
Unread post by Blaakk » 24 May 2014, 14:23
The Prev/Next buttons on the vst wrapper don't seem to work. A caption input/output for VSTs similar to those of the grid line module's captions would also be cool to be used in conjunction with these buttons.
Also... I'll requote woodslanding.....
woodslanding wrote:I think I've asked for this before, but I'd really like to have a file input on the VST object to enable loading FXPs and FXBs from disk programatically.
This is a much more robust and flexible way to recall settings in complex instruments such as Kontakt and Reaktor, as compared to the preset object, which is easy to break by modifying the patch.
a save input would also be nice. Or you could have one filename input, and a different input to trigger the actual saving or loading.
Or even allow a list of files, as with the usine sampler modules (although this is easy enough to do externally....)
thx,
-eric
+1 for the filename, loading, saving inputs/outputs.
And with the Grid..... I was trying to see not only the next caption for displaying on an interface, but the caption 5, 10 or 100 down, and then realized the 'move line down' could be used as a workaround. Is there any way to bind the selected grid line's 'move line up' or 'move line down' buttons, enabling one-by-one browsing of grid line titles?
Unread post by nay-seven » 26 May 2014, 10:51
For the prev/next, sadly all VST are not built in the same way..for example most of Reaktor ensembles react to those prev/next buttons but you'll find several VST who don't react...will be improved gradually
Blaakk
Unread post by Blaakk » 26 May 2014, 23:44
Ah ok. Cool. I've just resumed my Reaktor ensemble filtering I'll check it out. I'm sure there'll be workarounds for one's that don't work react.
Blaakk
Unread post by Blaakk » 27 May 2014, 19:56
Yep first Reaktor ensemble I tried this with worked. :)
Users browsing this forum: No registered users and 142 guests
