XY pad object size
gthibert
Unread post by gthibert » 06 May 2014, 14:58
I don't know if it's a bug or if I can't find the correct way to do it, but there it is.
When I change the size of an object (a ball) on the XY pad, the ball is not automaticaly recentered on his XY position. I need to touch the X and Y paramater so the ball return to the correct place. It looks like the ball is resized to bottom right instead of expanding from center.
I tried to use an ''has changed'' on the size to refresh the XY but it does'nt work cause the XY keep the same value.
Guillaume Thibert
Guillaume Thibert
www.cemproduction.com
Unread post by nay-seven » 06 May 2014, 15:11
I'm not sure to understand the question, can you upload an example patch to illustrate..?
gthibert
Unread post by gthibert » 07 May 2014, 04:01
Ok,
The problem is with the Draw XY Panel module
There it is :
intial state
I changed the size
I touch the X and Y fader after changing the size
Guillaume Thibert
Unread post by nay-seven » 07 May 2014, 08:55
do you change this size when patching, or in live situation ?
but it's right, we'll check this point
gthibert
Unread post by gthibert » 07 May 2014, 14:07
In live situation
Guillaume Thibert
Users browsing this forum: No registered users and 494 guests
