Newbie scripting help
ahonoe
Unread post by ahonoe » 26 Apr 2014, 03:11
Can anyone suggest why the following script doesn't work in HH? It has something to do with the setValue() but I don't know what.
// Basic counter
// parameters declaration
var incx : TParameter;
var countr : TParameter;
var reset : TParameter;
procedure init;
begin
incx := CreateParam('incx',ptButton);
countr := CreateParam('countr',ptDataFader);
reset := CreateParam('reset',ptButton);
SetIsOutPut(incx,false);
SetIsInput(countr,false);
SetIsOutPut(reset,false);
end;
// Global variables
var c : single;
begin
if (n = incx) OR (n = reset) then begin
fTrace(c);
c := c - (c*getValue(reset));
c := c+getValue(incx);
setValue(countr,c);
end;
end;
Thanks!
Regards,
Scott
Unread post by oli_lab » 26 Apr 2014, 15:35
// Basic counter
// Global variables
var c : single;
procedure init;
begin
SetMin(countr,0);
SetMax(countr,20000000);
SetFormat(countr,'%.1f');
end;
begin
case N of
0: begin
SetValue(countr,GetValue(countr) + 1);
end;
2: begin
c := 0;
SetValue(countr,0);
end;
end;
end;
Unread post by oli_lab » 26 Apr 2014, 15:40
better callback procedure :
begin
case N of
0: begin
c := c + 1;
if (c = 20) then c := 0;
SetValue(countr,c);
end;
2: begin
c := 0;
SetValue(countr,0);
end;
end;
end;
ahonoe
Unread post by ahonoe » 26 Apr 2014, 15:51
Thanks @OLI!
I'm a bit unclear as to how your changes make the script work. Is it the setformat() function that fixes the setvalue() issue? (I see by the ftrace() that the counter is working within my script. It seems that the output doesn't want to display these values.)
Regards,
Scott
Unread post by oli_lab » 26 Apr 2014, 17:02
this part allowed for the value to be more than "1" as I understand : SetMax(countr,20000000);
ahonoe
Unread post by ahonoe » 26 Apr 2014, 17:03
Thanks Oli!
Regards,
Scott
Users browsing this forum: No registered users and 47 guests
