simple midi keyboard patch for Hollyhock?
jjbonkers
Unread post by jjbonkers » 11 Feb 2014, 00:21
Hi all, does any know where I can get a simple polyphonic midi keyboard patch for hollyhock?
S
Unread post by nay-seven » 11 Feb 2014, 09:06
can you be more precise, you need a poly Midi patch on a tactile screen or you want use an hardware Midi keyboard ..?
jjbonkers
Unread post by jjbonkers » 11 Feb 2014, 13:20
Hi , its a poly midi patch that I'm looking for that is compatible with Hollyhock.
thanks
Unread post by nay-seven » 11 Feb 2014, 14:11
don't know if someone create a recent one, but maybe you can start with the add on named poly pads 2 , can be a good start ..?
Unread post by nay-seven » 11 Feb 2014, 14:34
here a quick start , y value on pads = velocity
midi pads
jjbonkers
Unread post by jjbonkers » 11 Feb 2014, 15:41
Ok will have a look thanks
S
Users browsing this forum: No registered users and 229 guests
