midi out not working
diggsta
Unread post by diggsta » 10 Feb 2014, 01:26
Hi, I've now tried this for hours, with no luck.
I want to use usine on a windows tablet to control with a few faders my daw on my real machine. I only have the free version of hollyhock up until now. As a wireless midi connection I tried rtpmidi and touchosc bridge, but in no case I get any midi out indication.
I do this http://www.sensomusic.org/wiki/doku.php ... k_midi_out but nothing happens.
couldn't be the midi wifi thing i guess, because it doesn't even blink the midi-out-led, and no tracing too.
What am I doing wrong?
iococoi
Unread post by iococoi » 10 Feb 2014, 07:07
did you activate midi outs in the setup? did you drag the midi devices in you rack?
your links goes to the v5 version of usine..
http://www.sensomusic.org/wiki2/doku.ph ... figuration
diggsta
Unread post by diggsta » 10 Feb 2014, 10:18
thank you so much!! I've just started using the software, and fiddled around for the whole day yesterday. I understood a lot of other concepts, but the dragging of devices into the rack was not one of them... you saved me the next few days :)
So now I see midi signals pushing through when using the random generator, but a fader still stays silent... How do I get the fader to put out midi? Somewhere else I read that I have to connect the fader to the code1-slot of the create midi tool, and then his out to the midi1 of midi out.
but that doesn't help.
little more help, please :)
Unread post by nay-seven » 10 Feb 2014, 10:47
Welcome diggsta,
here a basic example to create a Midi fader
here I've choose to send CC 36 in the create Midi module ( code 1)
i link a fader ( 0 to 127 as value) to the code 2
now with the has changed module, each time i move the fader the create inlet is triggered and send the midi message
diggsta
Unread post by diggsta » 10 Feb 2014, 18:33
wonderful!
thanks a lot!
it works!!
Users browsing this forum: No registered users and 119 guests
