Internal Messages
AndrewChi
Unread post by AndrewChi » 06 Jan 2014, 23:28
I'm just starting to look into IML.
I cannot seem to find where to open the .txt files from the Templates folder inside Hollyhock.
Is it possible to send IML-messages from the command prompt while HH is running?
Thanks!
Unread post by nay-seven » 07 Jan 2014, 17:52
you have to differentiate between templates and the send internal message module
the templates are text file you can find in the Usine/templates folders, you can edit and create your owns, to have personal menu when you create wires in patching.
the send internal message module lets you create and interact ( and yes dynamically) in patching mode, delete wires, create modules and so, currently this features is a bit buggy, but will be resolved next release
AndrewChi
Unread post by AndrewChi » 07 Jan 2014, 21:43
Ok, thanks!
Can or will it be possible to shoot internal messages directly from an Usine script, the chat window :) or way to access the console to open .txt files while Hollyhock is running (for batch-processing purposes)?
Unread post by nay-seven » 07 Jan 2014, 21:57
Can't tell you for chat window and console, maybe in the future, but yes for scripts :-)
AndrewChi
Unread post by AndrewChi » 07 Jan 2014, 22:03
Alright, that's great! looks like I'm gonna have a lot of fun this year :-) thx!
Users browsing this forum: No registered users and 29 guests
