preset manager
How does preset manager exactly works?
I have a patch with few subpatches (tremoresque) i added preset manager to main tremoresque patch. and when i store some state of the patch into preset manager and then i recall it i got something different as i stored. do i need somehow propagate this into subpatches, eg, create preset manager in subpatch, and wire it from main patch ?
One thing to check is that each object/sub-patch you want to recall have the option saved in preset ON
Hmm, that does'nt work as expected. I just uploaded new version of Tremoresque, but the preset manager is working still quirky - all necessary modules are configured with saved in preset option ON
i made a quick test of your add-on ( nice one, i love the design of sequencer when you decrease the steps) but can't see any parameter that are not saved...?
will try further if you confirm or precise more.
hmms, strange, i will try it with empty workspace
I am just discovering Usine, this is my first post.
I think the Usine environment is great.
I tried tremoresque and liked it a lot. However there is indeed a strange behaviour : the first line (kick) is always wrong when recalling a preset : it copies the parameters of line 2 instead. I am wondering, are there a lot of bugs like this in Usine?
I have tried to find the cause inside the patch, but I do not understand how the recalling of presets parameters work.
Can someone help?
I think it would be great to have tremoresque working as it should...
Thanks for you hard work !
Can someone help?
Welcome Emiliano,
You have to know that Tremoresque is an add-on, add-ons are made by our users, not by Usine team
So maybe Drakh (who made this patch ) can answer you in the addon section of this forum
I will also take a look on my side
ok, i understand, this addon was made with an older Usine version, so some minor changes corrupt the patch, here one who will work
Download
Download
Thank you !
the modified patch now works ok, the probability parameters are great... and the presets are recalled without bugs.
I understand that the add-ons are made by users and are not officially part of Usine, so I guess I will have to test each one thoroughly before I decide to use it.
Many thanks for your work.
