It would be a real comfort, especially on small screens (my stage laptop for example
full screen patching
La Tenaille
Have you try to use the floating windows option..?
La Tenaille
Yes I tried. I will try again but the screen is getting messy in this mode, the browser jumps to background, and there is no maximise button for the patch window.
yes, i know, but i think it's an habit question, once the patch window is maximize , double click to open/close, then CTRL+B and CTRL+I for browser and setting panel...?
La Tenaille
I'm giving this mode a second chance
An is there some option to swtich between windows using alt+tab (win7) ? Because in this mode you can not to switch between windows.
As a workaround i am using dexpot and its features...
Users browsing this forum: Bing [Bot] and 9 guests
