full screen patching
La Tenaille
Unread post by La Tenaille » 20 Nov 2013, 21:53
Could it be possible to have a way to toggle the patching area to fullscreen ?
It would be a real comfort, especially on small screens (my stage laptop for example :)).
Unread post by nay-seven » 20 Nov 2013, 22:01
Have you try to use the floating windows option..?
La Tenaille
Unread post by La Tenaille » 21 Nov 2013, 09:43
Yes I tried. I will try again but the screen is getting messy in this mode, the browser jumps to background, and there is no maximise button for the patch window.
Unread post by nay-seven » 21 Nov 2013, 11:14
yes, i know, but i think it's an habit question, once the patch window is maximize , double click to open/close, then CTRL+B and CTRL+I for browser and setting panel...?
La Tenaille
Unread post by La Tenaille » 21 Nov 2013, 13:08
I'm giving this mode a second chance ;)
drakh
Unread post by drakh » 22 Nov 2013, 13:29
An is there some option to swtich between windows using alt+tab (win7) ? Because in this mode you can not to switch between windows.
As a workaround i am using dexpot and its features...
Users browsing this forum: No registered users and 140 guests
