Vst parameters not updating
Bovo
Unread post by Bovo » 08 Nov 2013, 21:48
This has probably been asked before...
I'm controling a plugin with an external keyboard with knobs...
I'm able to control the vst parameters (I'm hearing the changes) but the plugin knobs don't move... How do I get the vst to reflect the changes I'm hearing?
Thanks for the help
Unread post by nay-seven » 08 Nov 2013, 22:03
Can depends of the plug-in and the way you control these parameters..
do you use a midi learn feature of the plug-in or have you create a knob from an inlet..?
Bovo
Unread post by Bovo » 08 Nov 2013, 22:18
I'm using my X-station (HW) to control V-Station (vst). I just plugged it through a midi module and all the vst params respond to the HW knobs, they're pre-mapped to work together... But I can't see anything move on the plugin even though I'm hearing the sound change...
Unread post by nay-seven » 08 Nov 2013, 22:59
ok, so I've download the demo version 2.2 windows version , and test with my Akai LPD-8 and CC n5 send and move the portamento knob on the interface..?
Bovo
Unread post by Bovo » 09 Nov 2013, 23:21
All I did was plug a midi module straight into the plugin, no fader, no other controler. I can manipulate all the parameters of the plugin with the external synth's knobs, but while I hear every change (adsr, filter, program changes, etc.), the plugin's knobs don't move, nor do the preset name... I'm used to have a visual feed-back, maybe I could do without... I need to see the right preset name at least...
Thanks for taking the time, I appreciate it
Unread post by nay-seven » 10 Nov 2013, 01:24
can you precise the version of the plug-in you use and if you are on a windows or Mac machine..?
i've test again with a nanoKontrol II and several parameters move on the plug-in
can you test this patch, here i see knobs moving
Download
