Usine Hollyhock Update #8 (1.02.012) is available for download
Announcements
Unread post by senso » 31 Oct 2013, 11:50
[large]Usine Hollyhock Update 8 (version 1.02.012)[/large]
This new version contains many important improvements and fixed bugs.
You’ll find 3 new devices modules: the Leap Motion module, the serial port module (to work with Arduino and other serial devices) and the Wiimote module.
Create some interaction with movements and gestures with the Leap motion. Built your own midi devices with the Arduino and sensors and conduct your patches with the Wiimote.
Improvements
new Serial and Arduino module
new Wiimote module
new Leap Motion module
new Clock module
new Count milliseconds module
new Change Scale module
new Counter module
new Quantize Data module
new Quantize Button module
new Quantize Midi module
improved midi clock management : directly included into the devices. Much more accurate and precise.
improvements in the Doppler library patch
improvements in the Queue Data in Array module
improvements in the Midi Quantize sub patch
fixed bugs
important memory crash on store/recall preset of plug-ins.
[Report #9] on plug-ins module, ‘params’ and ‘params names’ deosn’t update when changing preset
[Report #31] on plug-ins module, param value in setting panel deosn’t update when manipulated by patch
plug-ins module, in some case, bypass produces noise
various details in the Ramp module
mapping curves doesn’t work properly on binds
[Report #39] buttons and commands colors of the preset manager
Can be downloaded in the download area.
See the release notes for more information
To upgrade just copy the content of your old /Config folder within the MacOSX packet or the WIN directory.
headphoner
Unread post by headphoner » 31 Oct 2013, 12:32
Hi
Great!
Where are the arduino's examples ?
Unread post by nay-seven » 31 Oct 2013, 12:40
@headphoner : on their wiki pages
drakh
Unread post by drakh » 31 Oct 2013, 15:05
seems like something is missing in leapmotion workspace (win32) trying to open leap motion from start screen and in console i got Workspace not found PianoLeap.wkp
Unread post by senso » 31 Oct 2013, 15:41
package issue, fixed in the 1.02.012a
sorry
daviche
Unread post by daviche » 31 Oct 2013, 22:22
Cool ! I hope my troubles about Plugs + Preset manager will be solved. I'll let you know ! :D
Composer - guitar player
Dell INSPIRON 16 5645
Windows 11
RME Fireface UC - EVO 8
Jongleur
Unread post by Jongleur » 01 Nov 2013, 13:53
Thank you i load and I tried with leapmotion
Unread post by senso » 01 Nov 2013, 14:09
daviche wrote:Cool ! I hope my troubles about Plugs + Preset manager will be solved. I'll let you know ! :D
yes it is.
but you have to rewrite you presets (recall + save)
daviche
Unread post by daviche » 02 Nov 2013, 15:45
No problem !
Windows 11
CREDO
Unread post by CREDO » 03 Nov 2013, 20:48
Wow - Huge improvement to the preset manager!! Thank you!
tlg
Unread post by tlg » 04 Nov 2013, 19:29
Really excited about this update, hopefully I'll have time to dig into it in a week or two.
Users browsing this forum: No registered users and 273 guests
