New add-On for launchpad users: Midi tessel (with video demo)
Announcements
Unread post by nay-seven » 30 Sep 2013, 18:12
Midi Tessel v0.1
Inspired by the Monome appz named Tessel , by sleepersecond, Midi Tessel is a Launchpad patch, with 7 midi sequences. Each sequence have its own Midi channel, you can sets start and end for each sequence, reverse sequence, add FX’s and more.
Check the Video Demo
More infos to use the launchpad on its wiki page
Important: Remember you can now directly download add-ons from your browser/add-ons tab, by using the update from internet button.
ceasless
Unread post by ceasless » 02 Oct 2013, 23:30
There was a Launchpad in the mail already before you uploaded it, and I couldn't wait to spend some time Tessel-ing. Now that it has arrived I can say that this patch is seriously fun to work with!!
I did however seem to run into some performance issues running the demo in Windows 7 x64 using update7(e) 32-bit. CPU spikes and audio dropouts.
Unread post by nay-seven » 02 Oct 2013, 23:39
Really glad you appreciate it
About spikes, I've test it on Mac and win 32 only, will test tomorrow on win 64, have you try to replace audio players by Plug-ins..? same results..?
is it an recent computer ..? processor/ram
ceasless
Unread post by ceasless » 03 Oct 2013, 11:23
Sorry for the lack of details.
It's not a new computer, but it's not much of a slouch either:
- AMD 3ghz 940 (quad core)
- 4 GB RAM
I should maybe also mention that it is a Launchpad S, in case there is some processing for the previous (not class compliant) Launchpads that is no longer necessary and somehow has something to do with it (though I don't think it is very likely).
I tried both the demo workspace and a new workspace where I hooked up the patch to some plugins. Same effect, unfortunately.
Unread post by nay-seven » 03 Oct 2013, 11:31
ok,
Don't know about the S version,
Of course there's an important midi flow both way, have you try different block size values to check ?
lodsb
Unread post by lodsb » 03 Oct 2013, 11:52
i am having the same issues regarding the spikes/dropouts, the cpu time display usually shows something like 12% here and then occasionally a cpu overload (90%) and glitches without cpu overload. this is a x64 (old 2x2GHz xeon) + old launchpads.
Unread post by nay-seven » 03 Oct 2013, 12:44
ok, i'll see with senso what he can do, but on my oldest machine dual core 1,8 ghz, i can reproduce cpu overload when i use hight speed ( 1/64, 1/128) but increase the block size solves the problem ?
ceasless
Unread post by ceasless » 03 Oct 2013, 13:16
I wasn't switching speeds around much (not using anything as fast as what you are describing :) ). I'll give the block size option a try later though so that you have some more perspective on what the problem is.
Increasing the block size will also increase overall latency of Usine, right?
Unread post by nay-seven » 04 Oct 2013, 10:19
yes, of course,but it depends if you want to mix audio real time processing in the same time, if not you can increase it without real problems.
ceasless
Unread post by ceasless » 04 Oct 2013, 16:56
I just reproduced the issue in the newest (update7(f)) 32-bit version with block size 128. 64-bit version on Win7 x64 seemed pretty stable.
re: 'mix audio real time processing', i assume you mean incorporating live performance input such as vocals, instruments, etc? or some other distinction? because that phrasing is broad enough to include all computer related music software stuff :) (minus off-line bouncing)
Unread post by nay-seven » 05 Oct 2013, 09:33
About real time, yes was my idea, sorry English is not my native language, as you have certainly notice before, so my words are not always precise.. ;-)
About midi flow, will be solved next version
mdtellam
Unread post by mdtellam » 15 May 2015, 17:59
Hey all
new user here im trying to use midi tessel with a launchpad s, the newer version but cant get it to work,i can get the demo of midi tessel loaded i can select launchpad in the settings/midi both in and out but i cant drag the midi in or out to the in out boxes ?this part i do not understand
best
Unread post by nay-seven » 15 May 2015, 18:31
welcome
You need to open the devices panel and drag your launchpad in from here on the rack input
same for the launchpad out
mdtellam
Unread post by mdtellam » 15 May 2015, 18:54
hey thanks got it working now sounds cool with absynth ..like it cheers
Unread post by nay-seven » 15 May 2015, 18:55
great, thanks
djaychela
Unread post by djaychela » 14 Jun 2016, 09:31
Probably a sign of my complete newb-ness, but I can't find this? I have found the MIDI version, but can't find re-tessel? I've updated the list via the internet, still nothing?
Users browsing this forum: No registered users and 244 guests
