New Add-On : Homing Pad III
Announcements
Unread post by nay-seven » 20 Sep 2013, 17:11
Homing Pad III is a new version of the Homing Pad. A tool to create grooves in a new creative way.
Simply draw a path with the mouse or the finger, this will generate instantly a new groove.
new: Seven new sound banks included.
new: Click on another banks name to create a new variation of this groove.
new: You can also double click on each wave display to open a new window to adjust individually pitch and gain and drag and drop a new sample from the browser.
Works with Usine 1.02.011d and above
More infos on its Wiki page
Unread post by cmodica » 20 Sep 2013, 17:22
I will test it. Thanks it's seems very funny.
If i download it from the addons browser in Hollyhock where it is downloaded on my hard drive ? (Mac OSX)
Thanks.
Unread post by nay-seven » 20 Sep 2013, 17:37
On Mac and Pc add-ons are downloaded in the Usine/config/addons folder .
if needed , on Mac you can right click Usine.app and use the "Show package contents" menu
but the patch will be visible in the browser/add_ons too of course
sephult
Unread post by sephult » 21 Sep 2013, 01:10
Awesome, I was soo wondering what happened to Homing Pad....I love this.
iococoi
Unread post by iococoi » 21 Sep 2013, 10:25
hi nay-7
i seem to have some troubles getting this to work. basically it loads fine, but it doesn't function as such....produces no sound , [rnd all],[ clear] doesn't respond, laggy interaction in the panel/trajectory section..i'm on the latest hollyhock 64bit in win 7..
thanks,
marco
Unread post by senso » 21 Sep 2013, 10:39
works with 1.02.011d only
iococoi
Unread post by iococoi » 21 Sep 2013, 12:08
thanks for the reminder..i was on 1.02.011c
Unread post by cmodica » 21 Sep 2013, 16:18
OK Thank you. Very nice add-ons.
Users browsing this forum: No registered users and 148 guests
