midi switch
funkyguitarist
Unread post by funkyguitarist » 14 Sep 2013, 22:29
hello
i want to route my midi keyboard to different destinations inside one patch.
i need something like a midi patcher which determines to which pianoroll my input keyboard data is routed.
i want to switch different destinations via a combo box .
any help greatly appriciated
mark
Unread post by nay-seven » 15 Sep 2013, 00:08
You can use a data dispatcher ( data /data manipulation) for this , works for Midi messages too.
funkyguitarist
Unread post by funkyguitarist » 15 Sep 2013, 00:57
hi nay seven
thank you for the fast reply
i almost have it working
the selector is expecting an integer for the selection of the output
how can i convert the numerical output of a switch into an integer?
with a combo list it is already working but i need 8 separate buttons or switches.
cheers mark
Unread post by nay-seven » 15 Sep 2013, 08:50
A 0-1 switch outputs integer, so you can create 8 switchs with value ON=1, Off=0, then ON=2, Off=0 and so...
now use the group mode and link them all to the select inlet of the dispatcher, that's all
